House with old IHC system. Need new controller.
Draven
Hello i have a house with IHC. And need a new IHC win controller or an upgrade.
Its a IHC Win Controller 1.32   E1736001. I have installed this 2009..
Is there a way of replace this without changing the entire system ?
I am swedish so kindly help me if possible in English.
9 answers to this question
På 5.2.2021 at 08:38 , Astronaut skrev:
As the others have written, what you need is a new controller. All of your existing hardware will work with the new controller.
The new controller will allow you to use IHC wireless, to have network access and to use dimmers that work better with the controller than any dimmer you may have today. In particular, the new dimmers have feedback to the controller so that it knows the current output level. To get full value out of your controller you may want to upgrade your dimmers.
You will also need to rewrite to program running on the controller. The style of programming on the Visual 2 and 3 controllers are similar to your Visual 1 controller but still different and not compatible.
Hello, ok many thanks. Now i have a plan.
I talked to LK,s support (Patrik) and he said it will work with Visual3 controller (820B1600). I need to upgrade the firmware and then there is a import function. So my older program  can be reused, only small modifications ?
Hi Draven.
I dont Think that true, or Patric has access to some special Firmware or tools that is not available for the public. It’s not been posible for 15 years to import or converter Old Visual 1 to new Visual 2 or 3.
But Visual 2 code can be used on the Visual 3 controller.
Ok thanks. I will now get me a visual 3 controller.
I suppose firmware update and software is freeware and i get that on LK,s homepage ? And maybe a manual of the blocks that are used in a visual 3 controller ?
Yes. However, the version on the homepage is in Danish but an english version seems to exist. I seem to remember that a number of people have asked on this site for an English language version and I think they have also gotten directions on how to find it. I suggest you search for it on this site.
Got it now.:)
https://www.se.com/de/de/download/document/VIS.R.03.04.69/
  • -1
