  2. Thank you, Lars, for the input. I guess you're right. Any advise on a solution that would replace the IHC control units but could use the same infra would be greatly appreciated.
  3. Yesterday
  4. The end of life for the LK IHC controller, was announced on 31/8-2023, but I don't think that press release is available anymore. Before the EOL announcement, the controller had been on backorder for almost a year, and those backorders were never fulfilled. Beside that, it's not just the LK IHC controller that is no longer being manufactured. It's the whole LK IHC suite of products that is end of life, both cabled and wireless. Most of the LK IHC components has been sold out for over a year now. Unless there is a problem with your current controller, I would stick with that one until you plan to replace the entire LK IHC installation. The Visual 3 LK IHC controller is NOT very stable. Mine were not even 5 yours old before I had to have it replaced as it stopped working completely. It's only the visual 3 controller that can be replaced if it breaks, but only for a few more years. After that, there is NO support at all for LK IHC.
  5. Hello, My house has a very old (1998) version of the IHC and I'm looking for a (more if not the latest) modern version of the controller for the system. I heard they don't manufacture these any longer, can anyone guide me to a possible source for it, please. Best regards, Immu
  6. Sidste uge
  7. https://www.ihc-user.dk/forum/forums/topic/11459-min-vej-væk-fra-ihc/
  8. Det er snart 2 år siden at LK IHC udgik (både controller og wireless). Der kommer ikke et nyt produkt, som kan arbejde sammen med LK IHC, men i denne tråd https://www.ihc-user.dk/forum/forums/topic/10812-hvad-er-alternativerne-til-lk-ihc/ kan du læse mere om alternativerne til LK IHC. Langt de fleste alternative produkter er wireless og baser sig enten på ZigBee (den protokol som Wiser fra Schneider bruger) eller ZWave. LK IHC wireless benyttede Wavenis og kan derfor ikke bruges sammen med hverken ZigBee eller ZWave produkter.
  9. Vi startede renovering af vores hus i 2019, hvor vi besluttede os for at elinstallationerne skulle være IHC Wireless, da vi godt kunne lide friheden i at kunne sætte/flytte kontakter som vi havde lyst. Alle tryk er derfor IHC Wireless kombi relæer, og alle modtagere er IHC Wireless lampeudtag. Derudover har vi en IHC 3 Controller og strømforsyning i tavlen. Opsætningen gjorde at der ikke var brug for korrespondancer m.m., da der bare kunne tilsluttes de ønskede tryk, til de ønskede udtag. Vi fik aldrig gang i vores IHC Controller. Da vi nu skal i gang med renovering af vores 1. sal, har jeg igen kigget på IHC Wireless. Til min store overraskelse kan jeg se at IHC Wireless udfases, og at IHC Controller slet ikke laves mere. Og jeg har opgivet at prøve at få gang I Controlleren. Løsningen med IHC Wireless komponenter har fungeret upåklageligt, men jeg ønsker ikke at lave en hel 1. sal med komponenter der snart udgår. Derudover ville jeg gerne have en løsning der også kunne APP/stemmestyres. Derfor vil jeg høre om nogen her kender til den erstatning for IHC Wireless der skulle komme, eller om nogen har et løsningsforslag til vores installation? Jeg har søgt rundt på nettet, men de løsninger jeg finder kræver at IHC tryk er kablede og at styringen foregår i tavlen. Mvh Kenneth
  10. Hej Allan. Tak, det vil jeg have i baghovedet hvis/når jeg kommer i nærheden af dig, tak. Mvh Søren
  11. Tidligere
  12. Ja, efter IHC manden forlod adressen så det sådan ud, Dog en elektriker har styr på stærkstrømsinstallationen -:) Jeg drømmer om at en IHC kyndig kom forbi og gav 2-3 timers introduktion mod passende betaling -:) Anvender IHC Captain 1.61 på en Rasperry Pi.
  13. Har din elektriker virkelig efterladt din installation i den tilstand? Hvis røgsensoren er købt sammen med resten af LK IHC installationen, kommer de sandsynligvis med en relæsokkel, som skal have 24V fra en 24V output udgang. Derudover skal NC relæet forbindes mellem en 24V input indgang og 0V. Man kan dermed resette røgsensoren ved at afbryde 24V forsyning via 24V output udgangen. Men følger der ikke nogle installations papir med relæsoklen til røgsensorne? Da røgsensor normal bliver installeret med NC forbindelser, er de næppe programmeret allerede, da alarmen så vil gå hele tiden, da normal tilstanden er at der er en sluttet forbindelse mellem 0V og røgsensor indgangen. Men du er nød til at checke programmet for at se om de er programmeret, og hvilke ind/udgange der i såfald skal bruges. Vedr. alternativer til ELIT IHC link, så afhænger det af hvad du vil opnå med dem. Hvis det er for at kunne bruge Zigbee enheder sammen med LK IHC, så skal du have fat i noget trejdepart, som f.eks. OpenHAB eller HomeAssistant.
  14. Hej Lars -:), OK for at være mere præcis så blev det færdigmonteret for 3 år siden, kun nogle meget få ting er ikke i drift. IHC elektrikeren stoppede med at komme og blev væk og er ikke længere "tilgængelig" -:(. Desværre var det ikke besluttet da projektet blev igangsat at IHC ville blive droppet -:( men håbede dog på----. Korrekt det er LK (Schneider multisensor detector jeg mangler at få sluttet på systemet og jeg ved ikke hvad det skal sluttes til i tavlen (der er trukket kabel til forbindelsen). Hvis du har et alternativ til ELIT så hører jeg det gerne.
  15. Hvis din LK IHC installation virkelig kun er 2 år gammel, må det være en af de absolut sidste installationer som er lavet, da LK IHC blev trukket tilbage for snart 2 år siden, og Visual 3 controlleren var i restorder i mere end 1 år inden da. Eksister firmaet som lavede installationen ikke længere? Men tilbage til dit spørgsmål. Tag nogle billeder af din LK IHC tavle og læg dem op her, så er der sikkert nogen som kan kan give et kyndigt svar på hvad du har. Jeg kender ikke din røgsensor, men den ligner LK IHC røgsensoren, og ud fra de informationer jeg kan finde om den, skal den tilsluttes LK IHC på samme måde som LK IHC røgsensoren. Med ELIT IHC link skal du være opmærksom på at det erstatter din LK IHC controller. Det kan muligvis funger sammen med LK IHC controlleren, på samme måde som man kan koble 2 LK IHC controller sammen, men det er designet til at man forbinder LK IHC I/O modulerne direkte med ELIT IHC link isteddet for LK IHC controlleren, så der er ingen garanti for at det kan funger sammen med en LK IHC controller.
  16. 2 år gammel installation, skal have tilsluttet 2 stk Smoke Detactor ESMI Conventia EDC30. Vil drøfte at få ELIT IHC Link konfigureret mm.
  17. Jeg vil også gerne kende svaret
  18. Hej Tostarp. Ja desværre, systemet er solgt. Det er min fejl jeg ikke har fået slettet min annoncering.
  19. The official website (lk.dk) still have the Danish version, but not the English version. You need to create an account to access it, but everyone can create an account free of charge.
  20. I'm also looking for an archive of 1.32. The official website doesn't host the software anymore, unfortunately.
  21. HaMe
    IHC-anlæg er slukket
  22. Du kan gemme alle værdierne vha menuen men hvis det skal løbende gemmes skal du lave regler for det du vil gemme
  23. HaMe
  24. Nej, så er det bare at bytte den ud. Alle 230V-24V DC 72W PSU kan erstatte den du har. Jeg er selv fan af at holde en ensartet og "pæn" tavle og dervej køre med LK's IHC PSU. De holder også +10 år eller mere.
  25. Kan jeg få den til at gemme alle data på én gang, eller skal der være regler for hver værdi i funktionsblokken? Altså på hver måned, år, total tæller osv? Jeg forstår det nok ikke helt.
