26 -
Alt der er opslået af Tiago Britici
Can you give me the link?
IHC Captain or IHC Bridge require Hardware (raspberry pi) and I want a software solution like command fusion for example. If the IHC has an IP address and has well-defined IOs, there must be some way to send commands to it outside the java interface.
To IHC controller
The IHC is configured on the network with a specific IP address and a Port, correct? I would like to know if from this address I can send http commands via hyperterminal and / or any internet browser without going through the IHC java application.
Is there any way to do commands on IHC via the internet, for example, writing the google chrome layer contollerip:port command
Opdatering til IHC remote version 1.4.5
topic svarede på Tiago Britici's Jørgen Møllegaard i LK nyheder
I tried 10 times and I gave up, it always gives an error in 74% -
When it was an error, did you downgrade 2.8.4 firmware or did it again? And you used firmwareloader 1.3.3 or 1.0? Thank you -
And for my problem of serial number and RF version without their numbers. can anybody help me?
Every imported product goes through a human check. If the person who is checking my IHC searches the value of it in the home country, it should tax the same at 60% of the value. I would have to take that risk and hope not to be taxed. Brazil is the country that most likes to collect taxes in the world.
Importing in Brazil is just for the crazy, we have to pay at least 60% tax on the value of the product, it would be very expensive for me. Would you have some old versions of firmware that I could test to see if my controller returns to normal with the serial number? From the photos you can see that he is in perfect condition right. Thank you
I created the courage and I dismounted the IHC, very simple of course, just release the two rear latches and the front cover that has full access to the circuit. I taked some pictures to show how are my controller, and from what I realized there is only one connector that is what connects the main board to the USB, RF and I / O's card - it was well connected but I wiped the entire board before reconnect and reassemble the equipment. I tried again pass the 2.8.4 firmware and the same error continues at the end of the installation and the serial number 0 appears in the administrator. To try to solve the problem, I have the firmware reset_factory_default.zip that has here in the forum before putting 2.7.220 again and nothing has changed. With respect to JAVA, I have installed the 32bit version of 7.79 because it is the only one that does not give errors to access. You would have some other hint tip to help, a master firmware that can sometimes cause the controller to return to factory state. I am from Brazil, and here Schneider Electric has discontinued the IHC line and works only with KNX, that is, I do not even have the option to buy a new controller version 3 to solve my connection problem with IOS11. All the help is of immense value. Thank you so much
What was your install sequence? First firmware and then JAVA? I'm still in error here.
Good morning, when I pass the new firmware I wait until the success message, restart the controller and go to the administrator to see these options, can you tell me if there is any hardware or software problem in it? Any tips for disassembling the controller or is it easy to identify such problems on the board?
Could you give me any tips or do you have some disassembly tutorial of the controller?, I'll do it tomorrow morning to try to finish it the same day.
I did all the procedures, however, with the old firmware loader here from the forum, since with version 2.8.6 gave the error below. I believe that I will not get anything right, right?
Good morning, I was traveling and I returned today to do the tests. Regarding the radio version being in N / A for me is not a problem since I do not use RF and I do not have an antenna installed on the IHC Controller. As for uploading to 2.8.4 firmware I did several tests and all with the same error at 75%: - first downgraded to 1.7.199, hung up for 10 seconds and tried to 2.8.4 - error - then I used the firmware "reset_factory_default" available here in the forum and did the same procedure - error. I tried even disconnecting all the I/O's from the controller. What will be more than I can try? I tried to up the firmwares 2.8.1 and 2.8.3 and both gave the same error in the 75% Am I doing anything wrong? Just a detail to pass, my IHC software is in version 2.7.349 in English and the firmware loader is that I am using aqiu of the forum is in Danish, can this be a problem? Thank you I did numerous tests with several firmwares, all above 2.7.220 give an error but I can go back to 2.7.220 without errors. Regarding the radio version, I have no antenna installed and I have never used RF so this could be a problem in the update? Thank you
Thanks, but here it continues giving error to transfer the firmware 2.8.4
And did you do some non-standard procedure (disconnect something, for example)?
I used the firmware loader from Torben link above (1.3.3) and I downloaded o firmware directly from the lk.dk site and it always gives 75% error even downloading the firmware (14,426,112 bytes) several times. And did you do some non-standard procedure (disconnect something, for example)? Could you pass the firmware that was used in my email - tiagobritici@hotmail.com for me to test if the problem is even in the file? Thank you
I'm trying to do this on my 6.1 controller with visual and it's giving error. Could you tell me how you could upgrade? I tried straight through from 2.7.220 to 2.8.4 and when it reaches 80% it gives error and the controller no longer responds. Thank you
I have a similar problem. I Could not login with admin user. I created a new user as administrator and everything is ok.
I have the old firmware loader. Can I put the firmware in 6.1 or will it crash?
I have an IHC HW6.1 controller and can no longer communicate with the IHC Remote after upgrading from IOS11 to smartphones. Could you help me? I'm thinking of loading 2.8.4 firmware with an old firmware loader. Can I have problems?
I don´t have a iPad, smartphone Android 6.0 and iMac.
Thank you Lars1. I want to better understand your answer regarding question 3. I am from Brazil, here we have no way to acquire Visility Board, and our idea would be a software solution and not hardware as with the others too, I did not understand much about the IHC Captain, OpenHab and Domoticz but from what I saw, I have to have A server on the IHC controller, and believe me here in Brazil, this is very expensive. Would you have any option only via software? From question 4, I have the latest version of FW from IHC 2.7.220 and I do not have remote access success, I searched a lot here and did not find anything, if you can give me a hand I will be eternally grateful. Thanks a lot for the help.
