JJO
Alt der er opslået af JJO
  1. OK, got this solved. Had to add also the "Turn off" scenario from FB to the socket scenarios. I'm quite new to Wireless devices, so working with scenarios is new as well.... Now a follow-up question would be that one wired socket controlled by Output230 connection, where I have attached Wireless mobil stikkontakt dimmer, would also need that Output230 is ON in order to Wireless dimmer to work. What would be the recommended way to take that into account in 1.2.03.c FB that I'm using? Maybe always first sending ON to Output230 is not a good idea. Some modification to 1.2.03.c is needed - a check IF Output230 OFF, then turn ON and then continue with Wireless dimmer.
  2. Sorry for not writing in Danish. I have Visual 2 with Viewer FW 2.7.220. I'm using IHC Visual 2.7.349 (the newest software I could find in English). I have Wireless socket dimmers that I would like program to be operated in 1-button mode. There is a Function block (1.2.03.c) that seems to allow that, but still can't get it working and don't understand why not. 2-button mode works fine. I bet I'm not the first one with this problem, so could you help me? Due to language barrier I could't easily find help by searching on this forum, so links to other threads are appreciated as well. Then with Google Translate I'm most likely able to proceed...
