Download IHC VIS file from 6.1
Todchen
Hi
I am trying to download the VIS file from 6.1 controller with correct LK IHC Visual. I get the error message, file error this is not a VIS file or the file is damaged.
The scenedesign works fine to connect but just the access / download of the project file is an issue. Any proposal how to access?
br
Tomas
7 svar på dette spørgsmål
9 timer siden, Todchen skrev:
Hi
br
Tomas
Strange - the vis file is just an xml - try attaching it here if the file has been downloaded
2 timer siden, Mikkel Skovgaard skrev:
Its possible to download the file with IHC Captain so you could try that if you have an RPI lying around. Im not sure if the IHC visual downloads the file to a temporary file somewhere
Thx!!! Been looking for the temp file but not found. Will try out your proposal!
