Binding between item and thing stops working after reboot
kerm
Hi
i installed openhab 2 on pi2 and as soon as i reboot the pi then all my items stop working, then i can remove the link between things and item. rebind them and it will work until i reboot
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.ihc/2.4.0-SNAPSHOT/
i used this guid to install.
https://knab183.wordpress.com/2018/11/03/installing-and-using-ihc-bindings-on-openhab2/
6 svar på dette spørgsmål
Hi
I have just now flashed the PI with this image
openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img
then I putty into it and use the guide
I then added 2 dimmers to an item and a temp sensor to another item,
then Sudo Reboot
After the reboot I get this
PS by the way it was not happy with æøå only the first time I loaded from ICH after it restarted if could not understand æøå I therefor renamed all my items in ICH controller
events.log
openhab.log
@kerm, communication between openHAB and IHC controller doesn't work very well. Most of the communication ends up to timeout, which means that IHC controller didn't send response to IHC binding. You could try to increase the timeout which is by default 5000ms, but not sure if that will solve your problem. What are your IHC controller HW and SW versions?
You are using rather old version of the binding (around 1 year old), so I recommend to use newer one.
På 15.10.2019 at 17:41 , kerm skrev:
Hi
Nogen som har et link til hvordan man sætter Openhabian op mod IHC? Har fået Openhabian på en Pi3B og har installeret bindingen til IHC / Elko. Troede så at der ville poppe en "thing" op i min inbox så jeg kunne konfigurere login credentials. Men det gjorde der så ikke...
Linket ovenfor "knab183...." virker ikke, men går til noget rekvalmehalløjsa.
